Need Explanation about the DATA Simulation of 700Watts-BlueSun and 555watts JA Solar
Hi Good Day to everyone;
I need the answer about the below Project simulation, the Maximum Capacity of both are much the same 1MWp in the 1st Simulation I used 700Watts and the 2nd I used 555Watts but why is a big difference regarding the Production yield and the Performance ratio? hoping for your explanation thank you very much.
Hi Rene
thank you for the project files.
A look into the energy balance shows unusual Low-light performance gains and Reflection losses:
Did you select a module from our database or did you put your own values? Be careful with parameters for the low-light performance.
Kind regards
Hi, I selected PV Module in your database which is the 700W - Bluesun Solar Co. , so this means the module is wrong, thats why the performance ratio is too big ?
Hi Rene
yes, this is unfortunate. I forwarded this to our database team so the manufacturer can correct its values. Additionally we will check how to put closer checks for manufacturer input.
Meanwhile you could copy the module, uncheck, and re-check the Standard low-light performance setting to let PV*SOL calculate (estimated) reasonable values.
Kind regards
Hi Frederik;
    Thank you for my inquiry , also the 2nd thing is this we want to register our  solar modules in your Data base so that our own Modules are there, how can you do that in your part , also what is the requirement for registering our new panel in your data Base?
1 minute ago, Rene said:
the database  Standard low-light performance setting cannot edit right? how can i copy or cannot
By right-clicking you do open the context menu which offers to create a Copy. Official database entries are not mutable, copied entries (only visible to you) are.
Kind regards
  • 2 weeks later...
Hi Frederik Good Morning, can you explain or differ the Spec. Annual Yield, the PV Generator Energy(AC Grid) , the Own Consumption , and Grid Export for this Result , many Thanks.
This is the settings that have a consumption.
This is the simulation settings with PV system Going to grid .
Hi Rene,
while I still do not really get the question and you did not explain your question any further, I'll try to give an answer to what I guess might be your question.
You have shown two tables with results of two systems. The PV production is the same in both cases (spec. annual yield, PR, PV generator energy (AC)). The difference is just that in one case you have consumers that use parts of the PV energy directly, while the other part is exported into the grid. So in this case you just have some additional results listed there.
  • 2 weeks later...
  • 2 weeks later...
