RVinea Posted July 13, 2018 Report Posted July 13, 2018 Using PVSOL Premium 2018 in test mode. I keep getting the error message "Fehler beim Zeichnen des Objekts" and "Fehler beim Zeichnen des Prims" while my installation is in English. So I am not able to create a 3D visualization as these error messages block the program. Quote
developer_mh Posted July 13, 2018 Report Posted July 13, 2018 Dear RVinea, we are sorry to hear that you keep getting error messages in 3D. Could you give us some details about the steps that lead you to the errors? Thanks and kind regards, Martin Quote
RVinea Posted July 13, 2018 Author Report Posted July 13, 2018 Hi Martin, I've setup my sample project (location, climate, etc...) and then clicked on 3D design Edit Map Selection. When I click on the map, the project location is displayed correctly (sat picture) and the scale is updated (10.04). So far so good... When I hit the start button the error messages start coming up. Quote
RVinea Posted July 13, 2018 Author Report Posted July 13, 2018 I reinstalled the program but still having the same problem. Also noticed that no mater what option a select on the 3D design edit menu, I get the same errors. Every time this happens, I have to kill PVSOL via the task manager :-(( Quote
developer_mh Posted July 13, 2018 Report Posted July 13, 2018 Hi again, could you tell me what version of PV*SOL premium 2018 you are using (R1 to R9)? Also, could you send me the log file (C:\ProgramData\Valentin EnergieSoftware\log\PVSOLpremium.log), via private message? And if you don't mind, some information about the machine you are using would be helpful. Kind regards, Martin Quote
