Create a new PV panel
Hello,
I want to add a JINKO340PP panel that is not included in the database. What are the steps to create a new panel file for simulation?
Thanks
Maha
Hi Maha,
you can easily add your own PV modules (or any other type of product) to the databases by opening the database dialog (Menu 'Databases' then 'PV Modules'). Then select the manufacturer, in your case 'Jinko Solar'. Then you can either select a module, right click on it, and click 'copy'. Or you can add a new one by clicking 'new'. In both cases you can enter the datasheet information and save the new module by clicking 'ok'.
Here you'll find some more infomation:
https://help.valentin-software.com/pvsol/2018/databases/components/pv-modules/
