Stuart Patience Posted March 17, 2018 Report Posted March 17, 2018 Hi I have some projects we are looking at importing drone photos. Have read help and PDf but makes no mention of any file restriction. The OBJ file is 400mb! Ouch - is this too big if so what is the maximum size I get no error messages it just does nothing on import 3D model. Thanks Stuart Quote
developer_ah Posted March 20, 2018 Report Posted March 20, 2018 Hello Stuart, yes, 400MB ist far to much. PV*SOL ist a 32 Bit application. So the maximum size ist 250MB and the maximum number of points is 500.000. But even this can be to much, if you want to do a fast planning. Make you life as easy as possible and reduce the files on a minimum. The greather a model file, the more time PV*SOL need to calculate for ex. the shading, because every single Triangle of the model now can evoke shading. We apoligize the empty message. Its a error. It says that the file ist too big. Many greetings! Quote
