tiago202021 Posted March 5, 2018 Report Posted March 5, 2018 I'am trying to simulate an pv plant in house roof, when I export the 3d model in OBJ file format the shadow frequency increase dramaticaly if its compared to an COLLADA file format. I've done the simulation on the same scenario, only thing differente is file format. Does anyone know what I'm doing wrong? Thanks Quote
Chow Posted March 5, 2018 Report Posted March 5, 2018 I am curious to know as well, whether the different types of format exported from a SketchUp file influences the analysis  Quote
developer_ah Posted March 6, 2018 Report Posted March 6, 2018 Hello, case 2 is clearly an error that has already been reported. If the building contains a completely closed attic, the shading simulation has difficulty in correctly determining the shading. You can see this by the fact that some shading values of over 60% are of course much too high. We apologize for that and we're working on it. In the meantime, please create the attics in sketchup as several broken walls if you have created the sketchup file yourself. This should fix the problem. In the first case, the model is constructed in such a way that the error not occurs. Please be aware that the model geometries may have been stored in two different ways in the file. In one case, for example, only triangle faces are stored in the file; in the other case, for example, complete fans are stored. In addition, optimization may have become active when exporting to a certain format, so that different files can be created for the same model. Normally this does not affect the results of the shadow calculation! Many greetings! Quote
jamesbm Posted May 22, 2018 Report Posted May 22, 2018 Is there any news on a fix for this? I'm having the same problem. I have fixed it by using your suggested workaround but it would be nice to bot have to fiddle around so much. Thanks   Quote
