Dajana Posted March 5, 2018 Report Posted March 5, 2018 I know that the cabling option is not available for mounted modules. When I have a monted surface u just use the calculations as if the modules where on a roof and add to the cable length. My question is, when I have modules with east/west tilt is it possible to change the strings so that the strings are always connected on the same side, actually eveyr other module row? I could then use the calculation for aproximation of the length. Quote
developer_mh Posted March 5, 2018 Report Posted March 5, 2018 Hi Dajana, I am not sure if I understand your question correctly, but yes, when you have east-west systems, you can choose to (and you should) have all your modules facing east in one string and all modules facing west in the other. See this example: Here, I just connected all modules facing east to one inverter with 2 MPPT, and all modules facing west to another. Does that answer your question? If not, please don't hesitate to ask again. Kind regards, Martin Quote
