Mohi Posted January 19, 2018 Report Posted January 19, 2018 Hello, I'm a beginner on PV Sol. When I go to 3D Design to insert my site's image, in "New 3D System", there is no "Map section" option. I also have installed the photo plan. Could you help me? Regards, Mohi Quote
Stuart Patience Posted January 19, 2018 Report Posted January 19, 2018 You need to go into coverable object dropdown and select map - should pull address in from first tab. 1 Quote
developer_mh Posted January 19, 2018 Report Posted January 19, 2018 Hi Mohi, just like Stuart said, the map section can be found in the dropdown menu of "New 3D system". If you don't see it there, check the software version you have. This feature was introduced with PV*SOL premium 2016 Release 1. Kind regards, Martin 1 Quote
Mohi Posted January 19, 2018 Author Report Posted January 19, 2018 Thank you both My PV*Sol is premium 7.5 which is exactly the version before premium 2016 Release 1. Kind regards, Mohi Quote
