Patrik Posted November 21, 2017 Report Posted November 21, 2017 Hello, I want to ask about CD coupling system, I created BYD battery with DC coupling but there is an issue that the battery is not working properly. PV system should be working fine, but after calculating there is no use of battery for my application of grid connect battery system with own consumption. As you can see on the graphs above there is only battery charging but no use of battery storage to feed the load. Is there something that i did wrong or it is just your system issue ? I also tried a DC generator coupling but nothing changed. I also enclose project in attachments and the parameters below. I also want to regulate the feed-in the grid but i was not able to achieve this without operative battery system. Thank you for your help with this problem. It took me a lot of time solving this, but with no satisfying result. Patrik PVSOL_1.pvprj Quote
developer_mh Posted November 21, 2017 Report Posted November 21, 2017 Hi Patrik, thanks a lot for your question and for providing the project file, that always helps a lot. In your case there is actually no error, the battery is working well. It is just that in die diagrams the yellow bars are representing PV energy AND battery energy together (see the text in the legend). For DC coupled systems, the PV and battery energy are fed into the system on one common point, so the energies are displayed together. In the table view for the simulation results, you can see, how much energy is stored into and taken from the batteries: Hope that helps, kind regards, Martin Quote
Patrik Posted November 21, 2017 Author Report Posted November 21, 2017 Hi, Martin ! Yes, so battery is working but if I compared the AC/DC coupling for project it not working right, the usage of DC coupling battery is so low and there is a huge feed-in to grid. graph.1 : Without battery system. There is grid Feed-in 1243 kWh/y. graph.2 : PV system DC coupling battery system. There is grid Feed-in 1120kWh/y. So battery is working but it is so limited. There is enough capacity to store more energy and reduce the grid feed-in. graph.3 : PV system AC coupling battery system. There is grid Feed-in 199 kWh/y. As you can see when I use AC coupling PV system, there is a huge difference compared to DC coupling. And also no energy from grid is used to charge batteries. If i compare both systems there should be nearly same grid feed-in, if batteries are not charged from grid. Maybe there is something that i forget about. Thank you for helping me. Patrik Enclosed project in attachments. PVSOL_1.pvprj Quote
developer_mh Posted November 22, 2017 Report Posted November 22, 2017 Hi Patrik, I understand your doubts. There are two differences of DC coupled systems that you should have in mind when you compare AC and DC coupled systems: The DC coupled storage is only connected to one of the PV inverters. That implies that the other inverters are never participating in charging the batteries and all PV energy of the other inverters is fed into the grid if it cannot be used to cover the load in that moment The charging power of DC coupled systems is subject to the available PV power of the inverter. Only if the PV power of that inverter is higher than the load, the excessive PV power is used to charge the batteries. In your case the systems behaves like in the graph below very often: During the day, between 08:00 and 16:00, the PV power of inverter 1 (dark grey) is sufficient to cover the load (black) Please note that the dark grey line is PV and battery power together (as it is DC coupled) Only the (little) excessive energy of inverter 1 is used to charge the batteries (blue) The energy of inverter 2 (light grey) is nearly completely fed into the grid (red) between 09:00 and 17:00, as the load is already covered by inverter 1 In the evening, the batteries are discharged to help cover the load (yellow), but as there is only a small amount of stored energy in them, they are rapidly empty - also compare the SOC of the batteries (purple): This leads to a very small amount of battery energy used over the year. Hope that clarifies the matter a bit. If you have further questions, please don't hesitate to ask! Kind regards, Martin Quote
Nils Torbjørn Posted February 7 Report Posted February 7 Hi guys! It seems like I have an similar or relatable issue within this topic as well. I have tried to create a battery system with Solis Hybrid inverters and Dyness batteries. Attached you should find the PV*Sol file for the project. It seems like I can’t start the charging process. This building has a constant energy draw of 50kW, and a 110kWp PV system. One 60kV inverter and two 30kV Hybrid inverters. The plan was that the excess energy would be stored in the batteries and then discharged when there is no production, that way we can use all the produced energy on self-coverage. The task is to move the export to charging and discharging and when there is no production, it should self-use. Thank you for all the assistance, much appreciated. PV Sol Trøgstad Maskinhandel AS.pvprj Quote
hotline_oh Posted February 10 Report Posted February 10 Dear Nils Torbjørn, Thank you for your inquiry. Only a quarter of the desired system was connected, so the batteries were never charged. The configuration could look like this: Then the simulation works: Quote
Nils Torbjørn Posted February 10 Report Posted February 10 Hello Admin and thank you for the quick reply! Much appreciated. Sadly, these pictures does not explain very easily to me what i have done wrong. I noticed that you changed the hybrid inverters, the ones i used was user created. Maybe i did something wrong there. But you say only 1/4 of the system is connected, I do not understand what that means, where is it not connected? Is it possible for you to attach the PV*Sol file you printed these pictures from too me? That way i can open it and check what you did different? Thank you for the support! Quote
hotline_oh Posted February 11 Report Posted February 11 Dear Nils Torbjørn, Thank you for your inquiry. Please find the file attached. PV Sol Trøgstad Maskinhandel AS VAL.pvprj Quote
Nils Torbjørn Posted February 11 Report Posted February 11 Hi Admin! This does not help. You did so many changes to the system that its not the same anymore. You completely changed the entire battery-system with a AC coupled solution. (See attachment). What i want is a DC-coupled system, that's what i am offering our customers. If PV*Sol is not up do date with the DC-coupled systems please let me know. As far as the flow graph goes, that looks perfect. It's a very nice visualization of the cycles and the energy flow. With a DC-coupled system we might reduce the loss in AC/DC conversion alot. It's 1200 kWh. Almost 1/4 of available energy. Again, thank you for the support, much appreciated. Quote
hotline_oh Posted February 12 Report Posted February 12 Dear Nils Torbjørn, Thank you for your inquiry. We have understood that you want to design a 110 kWp PV system (192 PV modules) with three inverters (1 x 60 kW and 2 x 30 kW) and that the charging process does not work in the simulation. The reason for the charging process not working was that you had only configured 30 kW (48 PV modules). We then designed a system with 120 kW (192 PV modules) in 2D to show how the battery system can be integrated. Of course, you can also design the system as a DC-coupled system. However, the battery system you require (30 kW Solis hybrid inverter with Dyness battery) is not yet available in our database. We have also modelled your roof layout with 192 PV modules (as we assume) in 3D and connected it with 4 x 20 kW hybrid inverters and 4 x 29 kWh battery capacity. Please find attached the project file we have been working on. PV Sol Trøgstad Maskinhandel AS _ VAL.pvprj Quote
Nils Torbjørn Posted February 19 Report Posted February 19 Thank you for the response and sorry for my delayed answer. ''The reason for the charging process not working was that you had only configured 30 kW.'' I could not understand why you kept saying this because i connected all the modules. Seems like i have managed to forward the wrong file in my first inquiry. Sorry for that. As far as the energy flow graph everything seems to be as wished. It’s as DC coupled and almost nothing to export. And the loss due to AC/DC conversion is drastically decreased. I will look at the attached file and see if I can figure what is what. Quote
