Dear Sirs
I used the PVsol premium R9 2017 for a few days in the demo version, I liked the software and bought the premium license for student.
When I received the code serial, I did the whole procedure and registered the software without any failure, the problem is when I will use the software,When the PVSOL is opened a message appears that the time has expired and I can not open the program, I bought and the serial code arrived Today by email, it is impossible that it is already expired.
I need your help.
Thank you
Martin,
Unable to start the software, I have uninstalled and installed several times and with no results. The program says that it is registered but does not start the software, I will attach some images, I am from Brazil so the language will be in Portuguese, already tried to install in English but the software always installs like the first time it was in Portuguese.
I need help, I need to use this software to simulate some arrangements for my college work that was the reason I bought the license but I can not use it and the time is passing.
  • 11 months later...
  • 7 months later...
dear, I have a same problem as Tiago . The program says that it is registered but does not start the software . My  firm bought the license, and I wanted to switch it from one computer to another and sent the serial number deactivation form. Can you help me ?
Thanks
