developer_mh Posted January 27, 2023 Report Posted January 27, 2023 Hi Marius Fourie, thanks a lot for the video. We had a similar issue in R2 that was actually fixed with 3D. Could you provide the project file, please? You can send it to me by private message here in the forum, thank you. Kind regards, Martin Quote
IB Bresinsky Posted February 3, 2023 Report Posted February 3, 2023 Hello, same happens with my project. Funny thing: I did it a few days ago and it worked allright. Yesterday, it stucks at simulations step with same symptoms as described by Marius! A first (older) version still works, but whenever I change buliding heights of the surrunding building (due to shadowing issues), it also stucks in simulation step. I am helpless and customer is waiting for results! I can provide both project files (working and non working). KR, Dipl.-Ing. (FH) Jan Bresinsky Quote
developer_mh Posted February 3, 2023 Report Posted February 3, 2023 Dear Jan, yes, please provide both projects! That would be very helpful as we still didn't receive other projects where this happens. Thanks a lot, kind regards, Martin Quote
developer_mh Posted February 3, 2023 Report Posted February 3, 2023 Dear all, Thanks to the project files Jan sent me, we were able to find the bug. It will be fixed in the next release. In the meantime, you can use the Force Simulation command from the Options menu as a workaround if the simulation gets stuck. This will only happen on 3D projects that you have already simulated, if you go back to 3D, change the shading objects (and nothing else) and then simulate. Â Hope that helps, kind regards, Martin Quote
