Why battery is not charging some times on pvsol
Hello
i am facing this issue many times my battery is not charging on pvsol for many projects can i know why?
i attach my pvsol file too
Northampton.pvprj
Hello anees,
your battery is simply too small. 5kW charging/discharging power faces 450kWp from your photovoltaic system (a ratio of 1:90). This leads to high energy amounts per time step in which case the battery simply refuses to charge or discharge since it cannot deliver.
By increasing the connecting battery powers and capacity you can get into domains where your battery is able to handle relevant energies:
I hope this points you into the right direction!
