anees Posted October 13, 2022 Report Posted October 13, 2022 Hello i am facing issue in a project that battery is not charging from PV. I see that it was charging but and pvsol report show me its values but now i am seeing no charging from pv system size is 402kw 4 inverters sun2000-105ktl i attach how arrays looks   simulation values Quote
developer_fw Posted October 14, 2022 Report Posted October 14, 2022 Hello anees, thank you for your request. Could you send a project file via private message here in the forum so we can have a look into it? Kind regards, Frederik Quote
developer_fw Posted October 21, 2022 Report Posted October 21, 2022 Hi anees, I assume this is connected to the following thread: Kind regards, Frederik Quote
Lena Posted December 19, 2022 Report Posted December 19, 2022 Hello I have the same problem - in summary it seems like the battery can't be used. My installation is quite small as it's only 5,63kW. I chose SOFAR HYD3600-ES hybrid inverter and tried different batteries 3,8 to 5 kW. Even though information in battery system tab always was green, there was no battery on the chart, unless the battery was on AC side Quote
developer_fw Posted December 21, 2022 Report Posted December 21, 2022 Hi Lena, I assume your question could be deleted since you opened a new thread also... Kind regards, Frederik Quote
