December 8, 201510 yr comment_671 Hello! I created my first PVSol project in PVSol Premium 2016 demo and I have no idea how can I place cables. I have module strings on frames and almost every option turned grey or just doesn't work for me (attachement). Report
December 15, 201510 yr comment_674 Hello, The cable plan option in the 3D visualization only works for modules which are planned with the module coverage option. If you have planned modules with mounting systems then the cable plan is not available in 3D. Best regards Your Technical Support Report
February 22, 20179 yr comment_1037 Dear Team , how to create the cable plan for the pv panels created with mounting system in 3D . can we create the cable plan , by exporting the plan to 2D or another other way possible for it. Report
February 27, 20179 yr comment_1038 Hi Team, I need to export the cable length details to excel. can it be possible to export it . Thanks Report
February 27, 20179 yr comment_1039 Dear allan, for mounting systems it is not yet possible to create the cable plan in 3D. However, if you plan your mounting system in 3D and go back to 2D, you can enter your cable lengths and other details on the page "Cables" when you select the detailed option. In the info dialog at the bottom of the page you'll find a summary of all cables and other components. Hope that helps, let me know if you need any other assistance. Kind regards, Martin Report
February 27, 20179 yr comment_1040 Hi Martin, Thanks for the details. i like to export the cable details summary to pdf or csv format .Can it be possible. Thanks Allan Report
February 28, 20179 yr comment_1042 Hi Allan, I'm afraid this is not possible at the moment, but we will put it on our todo list. Kind regards, Martin Report
