jerryg Posted November 10, 2015 Report Posted November 10, 2015 Hi I'm have problem when I combine two module areas. Inverter selection no longer works, no suitable inverter configurations could be found And if I manually try to configure system there is no option to add a second inverter? No option to add second inverter Automatic selection fails with this message Any suggestions or help with this? Quote
hotline_sf Posted November 13, 2015 Report Posted November 13, 2015 Hello jerryg, please take a look at the following topic: http://forum.valentin-software.com/topic/199-combining-different-strings/ Maybe this will help. Best regards Your Technical Support Quote
Airel Posted November 16, 2015 Report Posted November 16, 2015 I have a similar problem My own inverter dont appear in the list, so I cant add it to my connection. I am trying to combine two module areas to connect to a 500 kW inverter, 12 DC inputs, 1 MPP tracker. Please help me. Thanks in advance Quote
hotline_sf Posted November 16, 2015 Report Posted November 16, 2015 Dear Airel, If you combine two module areas in the inverter selection window then the software only show inverters with two MPP trackers. You have to configure the module areas to seperate MPP trackers. From your pictures it seems that you have two module areas with the same orientation and tilt. So. you could group the module areas before you configure them. This is described in the following topic: http://forum.valentin-software.com/topic/213-inverter-selection-in-module-configuration/ Your Technical Support Quote
Airel Posted November 16, 2015 Report Posted November 16, 2015 Support Team, thanks for your quick response. The real cause of my inverter not appear is that their configuration was different phases of the system, corrected. The real problem I have is that my inverter is 12 entries DC, I planned 7 parallel series of 16 modules in series per entry, so I grouped the modules in the 2 areas of modules, but the program creates 84 series of 16 modules in series and I find no way to configure the parallel connections. Judging by the color code, it will apparently accommodating each series of 16 at an input, so that the row i + 12n is assigned to the input i. That I like is that rows 1-7 will be connected to input 1. 8 to 14 to the second, and so on.Is this possible? Can you help me? By the way, how can I pan, zoom or rotate the image in the graphic view? Quote
hotline_sf Posted November 18, 2015 Report Posted November 18, 2015 Hello Airel, For the simulation it doesn't matter how many entries you have on your inverter. Only the MPP tracker is important. The MPP tracker has to handle 84 series of 16 modules even if they are connected to different entries. Best regards Your Technical Support Quote
julienmen Posted November 25, 2016 Report Posted November 25, 2016 Hi,I tried to do something similar but could not find a way.I have 3 different roof with 3 modules formation with different orientation (1 with 20 modules and 2 with 35 modules). I want to use 1 inverter (SMA STP 25000 to be exact) as I would do in real life but I can't do it on PVSOL Premium. When I want to regroup formations, it don't work. and when I combine 2 formations in the inverter selection window, I can't fin an inverter that match the config. What should I do ? Quote
