Configuration issue using Huawai sun2000KTL 10 M0
Hello  i want to configure 26 SOLYCO-R-BF-108p.3-400 with Huwai sun2000-10ktl-m0
what i did i use 2 strings of  13 and face  error that i attached
inverter datasheet says that input current is 22A
all datasheets are attached
Please help me to figure this issue Thanks
inverter dataheet.pdf Module datasheet-SOLYCO-R-BF-108p.3-400-2021-12v2_en.pdf
Hi anees,
the inverter datasheet states 11A per MPPT:
which gets confirmed by our configuration check:
so everything is fine, PV*SOL just informs you about the invalid configuration. You either have to choose less modules per MPPT or a greater inverter e.g..
I hope that helps.
