Janne Posted February 15, 2022 Report Posted February 15, 2022 Hi. On the flat top roof in the attached image I want to place the panels directed to the south. Now I just get them lined up with the edge of the roof to the southeast. I there any solution here? /Janne Quote
developer_mh Posted February 17, 2022 Report Posted February 17, 2022 Hi Janne, for mounting systems you can enter the orientation of the modules with respect to a reference edge of your choice: While this is the method I would recommend, there is also an option to set the reference edge for the module coverage (i.e. without mounting system). In order to choose the reference edge you want, right click on the extruded building, select edit, and then set the reference edge: Then, when you cover the roof with modules, they will be aligned to the edge you chose as reference. Hope that helps, kind regards, Martin Quote
Janne Posted February 21, 2022 Author Report Posted February 21, 2022 Thx Martin. When I followed your recommended solution it was easy to get the modules in the right direction. Janne Quote
Kristian PA Posted August 27, 2025 Report Posted August 27, 2025 Hi! When I do this for an inclined roof the inclination automatically follows the reference edge. I am working on an architect roof where the roof is skewed, hence I want to change the reference edge. But then the inclination is changed. Is there a way to lock the inclination to a certain edge? Quote
hotline_oh Posted September 1, 2025 Report Posted September 1, 2025 Dear Kristian, Thank you for your inquiry. You can only specify one reference edge per roof (not multiple). If you want to define multiple PV arrays with different orientations on a roof, you specify the new orientation relative to the reference edge. If the roof has a slope, you specify different slope angles for the different PV arrays if necessary. PV*SOL will always calculate the resulting slope for each PV array. Did we understand your question correctly? If not, please send us a screenshot, a sketch, or your project file, and we'll take a look. Quote
