Faruk Posted July 22, 2021 Report Posted July 22, 2021 To whom it may concern, How to have situation where the surplus of PV energy does not go to the grid, but the loads are connected to the grid to be fed by the grid when there is no PV output? Best regards, Faruk Quote
developer_mh Posted July 27, 2021 Report Posted July 27, 2021 Hi Faruk, in order to avoid grid feed in you can set the maximum power clipping to 0%: https://help.valentin-software.com/pvsol/en/pages/system-type-climate-and-grid/#ac-mains Hope that helps, kind regards, Martin Quote
Faruk Posted July 27, 2021 Author Report Posted July 27, 2021 Hi Martin, Thank You for the information. Best regards, Faruk Quote
aponsa Posted September 1, 2021 Report Posted September 1, 2021 Hi, When setting maximum power clipping to 0% for the case Faruk described (surplus of PV energy does not go to the grid, but the loads are connected to the grid to be fed by the grid when there is no PV output), which "Energy Balance/Feed-in Concept" should we use? Surplus Feed-in or Netmetering? I understand from an economic point of view that this should not be too important, but maybe there's a diference for the program?  Could you advise?  Thank you, Quote
developer_mh Posted September 16, 2021 Report Posted September 16, 2021 Hi aponsa, the decision which economic concept you must apply does not depend on the feed-in clipping. It does depend on your local tariff. In Germany for example with have surplus feed-in tariffs. In other countries like Brazil or Poland, net metering tariffs prevail. Kind regards, Martin Quote
GIM Posted November 20, 2021 Report Posted November 20, 2021 To not open new topic writing here. How to input tariff right. Have such a situation: I have price of energy I buy from the grid (0,15eur/kWh) Also I can save my power "in the grid" when sun is shining and plant producing more than needed and return kWh when is needed (night time or winter) for 0,05eur/kWh. Also I sell the annual rest to the grid provider for the fixed price (0,04eur/kWh). I use the "Net-Metering" method. Also fulfilling "Net-Metering tariffs" with "Tariff period 1" "Energy price" 0,15, "Compensation for Surplus" 0,04 with "annual accounting". And the question is how I need to enter a tariff for my saved and after returned power??? Thanks for your support. Quote
