June 3, 20215 yr comment_5537 Hello, I have encountered a problem with the consumption results for one of our sites and I was wondering if you could help please. First I had a 300kw system with these details: PV Generator Output 300.1 kWp Spec. Annual Yield 839.66 kWh/kWp Performance Ratio (PR) 88.0 % Yield Reduction due to Shading 0.8 %/Year PV Generator Energy (AC grid) 252,159 kWh/Year Own Consumption 180,016 kWh/Year Down-regulation at Feed-in Point 0 kWh/Year Grid Feed-in 72,143 kWh/Year Own Power Consumption 71.4 % CO₂ Emissions avoided 118,439 kg / year Appliances Appliances 607,209 kWh/Year Standby Consumption (Inverter) 161 kWh/Year Total Consumption 607,370 kWh/Year covered by PV power 180,016 kWh/Year covered by grid 427,354 kWh/Year Solar Fraction 29.6 % And then we increased the size of the system to a 1250kw system with these details; PV System PV Generator Output 1259.5 kWp Spec. Annual Yield 834.08 kWh/kWp Performance Ratio (PR) 87.6 % Yield Reduction due to Shading 1.0 %/Year PV Generator Energy (AC grid) 1,051,828 kWh/Year Own Consumption 252,228 kWh/Year Down-regulation at Feed-in Point 0 kWh/Year Grid Feed-in 799,601 kWh/Year Own Power Consumption 23.9 % CO₂ Emissions avoided 493,755 kg / year Appliances Appliances 607,209 kWh/Year Standby Consumption (Inverter) 1,287 kWh/Year Total Consumption 608,496 kWh/Year covered by PV power 252,228 kWh/Year covered by grid 356,268 kWh/Year Solar Fraction 41.5 % Could you please explain why the “own power consumption” had gone down from 71.4% to 23.9%. This client is looking to go completely on Solar so would use a lot more than 23.9%, is there a way I could say that they will use 100%? Many thanks Matt Report
June 3, 20215 yr comment_5538 Hi Matthew, the answer to your question is concurrency. Only if the higher amount of solar energy can be used just in time, you could raise your solar fraction. In your case you produce more solar energy which you cannot use, since your appliances simply are not able to consume this overproduction. This is why your grid-feed-in is getting so much higher and your own power consumption is getting so much lower respectively. To reach a high solar fraction (i.e. maximize your own power consumption) the only solution might be an energy shift which leads to batteries. The other way is to adapt your appliances as much into the period of solar energy production as possible. In some use cases, this is possible, in some other ones it is not. Reaching 100% is not impossible but in many cases uneconomical. Plus it depends on how adaptable your use case is. If you have further questions, feel free to ask. Best regards, Frederik P.S.: Have a look into some graphs showing the load of your appliances and the PV power production to get a better feeling for this problem. Report
