anees Posted May 27, 2021 Report Posted May 27, 2021 my 3d window is totally deformed its on menu option same is with other window Quote
developer_fw Posted May 27, 2021 Report Posted May 27, 2021 Hello anees, thank you for your report! Do you use the native screen resolution or do you use a scale setting in your display settings? There you will find an option for scaling. We did fix scaling issues in a previous release, therefore I want to make sure this is not related. Best regards, Frederik Quote
anees Posted May 27, 2021 Author Report Posted May 27, 2021 11 hours ago, developer_fw said: Hello anees, thank you for your report! Do you use the native screen resolution or do you use a scale setting in your display settings? There you will find an option for scaling. We did fix scaling issues in a previous release, therefore I want to make sure this is not related. Best regards, Frederik yes i am using it on multiple screen on external its working well but not on other Quote
anees Posted May 27, 2021 Author Report Posted May 27, 2021 3 minutes ago, anees said: yes i am using it on multiple screen on external its working well but not on other i uninstall and install that but nothing happen Quote
developer_fw Posted May 31, 2021 Report Posted May 31, 2021 Hi anees, PV*SOL does work on one screen but not on the second? This is hard to reproduce, since many of us use two screens as well and 3D does work on both screens. Did you try different setups, e.g. only one screen attached? I'm not sure if this is an issue caused by PV*SOL. Best regards, Frederik Quote
kris Posted August 25, 2021 Report Posted August 25, 2021 Hi, i have the same problem but on both screens. Where is the problem? I checked other resolutions and scaling. Nothing helps. Quote
