Hi everyone, :)
What the best way to optimise the consumption (tweak the consumption profile ) to get a really good PV design?
The scenario is that we have an office building with 80000Kwh annual consumption.
The Solar system generates 130000Kwh annually.
Somehow i can't find any consumption profile (or create one) to maximise the OWN Usage.
I would like to increase these figures i highlighted with red in the attached. (Direct own usage and own consumption)
I know its down to the hours of consumption and i am prepared to create a consumption profile to optimise the system. I have tried editing the PVSol profiles but not succeeded so far...
any help, ideas, suggestions would be much appreciated :)
Cheers
Steven
Hi SolarStevo,
load profiles is a tough topic because of many unknowns. I just created a project with a custom load profile respecting a certain higher load from 8 am until 6 pm on workdays and a relatively low load for the weekend. In the summer at noon there is also a little higher load due to cooling. This resulted in a higher solar fraction since load and solar energy overlap more often.
The solar fraction gets higher:
Of course there is a limit, but I guess this clarifies the common question of getting a higher solar fraction.
So did you manage to edit the profiles so far? This is possible on the page Consumption, after opening/adding a profile. A system data set can be edited after copying it. The input table is a bit cumbersome to use, but the overall concept of having different profiles for different days and so on pretty straightforward.
I hope this helps! If you have further questions, don't hesitate to ask!
Best regards,
Hi Frederik,
Thank you very much for your help. :)
I will give this a go and create a well optimized profile for the sunny hours and see how far i can take it :)
I was hoping to achieve about 80 to 90% percent of Solar Fraction.....i know it's a bit ambitious :)
Thank you
Steven
  • 2 years later...
Hello Madhava Sai Kiran
On 8/6/2023 at 5:51 AM, Madhava Sai Kiran said:
how can I increase my solar fraction
I guess this will only be possible with overlapping production and consumption or increasing your battery capacity e.g.
Kind regards
