Pro GD Engenharia Posted December 27, 2020 Report Posted December 27, 2020 Estou capturando imagens por DRONE e posteriormente gerando arquivos em 3D e na escala correta (metashape), salvando com pontos de face menor de 50 000. o PVsol abre os arquivos porém não tem a opção USAR COMO MODELO DE TERRENO, consequentemente não é possivel ATIVAR e inserir os modelos de placas e tudo mais. Além disso os programas estão abrindo com inclinação... Quote
developer_mh Posted January 4, 2021 Report Posted January 4, 2021 Dear Pro GD Engenharia, I translated your post with deepl.com, I hope it is correct: Quote I'm capturing images by DRONE and then generating 3D files in the correct scale (metashape), saving with points of less than 50 000 face. PVsol opens the files but it doesn't have the option TO USE AS LAND MODEL, consequently it is not possible TO ACTIVATE and insert the plate models and everything else. Also the programs are opening with inclination... Would it be possible for you to send the 3D model file over to us so that we can have a look? Please send it here in the forum by private message, thanks. Kind regards, and a good start into 2021, Martin Quote
Venkatesh Posted May 17, 2022 Report Posted May 17, 2022 Hello. could you please update the solution about this issue here. I am facing exactly the same situation. Quote
developer_fw Posted May 17, 2022 Report Posted May 17, 2022 Hello Venkatesh, might it be possible for you to send the 3D model file to me via private message here in the forum so I can take a look? Thanks in advance and best regards, Frederik 1 Quote
