RicardoM Posted December 10, 2020 Report Posted December 10, 2020 Hello dear developers, I just noticed that Huawei inverter SUN2000-36KTL shows a maximum current of 26 A per MPPT: Â However, looking at the datasheet, that value should be 22Â A: Â Can you please double check and if needed fix the value in PV*SOL? The difference means one or two strings per MPPT, which as you can imagine is quite significant. Thanks!! Â Quote
developer_fw Posted December 11, 2020 Report Posted December 11, 2020 Hi RicardoM, I double checked the inverter values from our database: The 22A max. current per MPP is correct. Could you send me your project file for further investigation via private message? My configuration limits show 22A. Thank you in advance and sorry for the inconvenience, Frederik Quote
RicardoM Posted December 14, 2020 Author Report Posted December 14, 2020 Hi Frederik, I think I found the issue, apparently I have two versions of the inverter, one of them is the one you have with 22 A and the other one has 26 A. This second version appears created by a hidden user, which I guess must have been a colleague of mine. No need to worry then, now I know what I need to use. Thanks! Quote
