RicardoM Posted November 12, 2020 Report Posted November 12, 2020 Good afternoon dear developers, For some of my previous projects I've been using the Jinko 525 Wp module (please see attached datasheet), which does not yet exist in the PV*SOL databases, so I created it. Unfortunately, now that I try to use it again, I can't find it anymore: If I open my old project, there I can find it, no problem: What can I do to make this module (or any others I create) permanently available for all my projects? Also, any chance this module will be officially uploaded by PV*SOL? Thanks and regards, Ricardo  TR JKM520-540M-7TL4-V-A1-EN.pdf Quote
developer_mh Posted November 13, 2020 Report Posted November 13, 2020 Hi Ricardo, it seems that you database user id has changed from one PV*SOL to the other. Perhaps you re-installed PV*SOL on a new device? If so, make sure that you take along your database user id from the computer where you entered the PV modules and enter it in the newly installed PV*SOL. Read more here: https://help.valentin-software.com/pvsol/2020/databases/#user-ids https://help.valentin-software.com/pvsol/2020/options/#databases Hope that helps, kind regards, Martin Quote
RicardoM Posted November 13, 2020 Author Report Posted November 13, 2020 Hi Martin, Thanks but no, I did not install it in a new device. I've been using the same one for quite a while already... Any other option? How can my user id have changed and how can I prevent that from happening again? Kind regards, Ricardo Quote
developer_mh Posted November 13, 2020 Report Posted November 13, 2020 Hi Ricardo, ok, this is strange. Usually the user id is not renewed or reset except when you install it on a new device. One quick work around for you would be to copy the module with hidden user id when you open the project file where it is contained. This would make it available for you in other projects as well. I'll ask you to send me some files via private message in order to analyse the problem. Kind regards, Martin 1 Quote
