R4 causing lots of issues with layout:
  1.  Two Project fields on Project Data Tab, layout also looks clumsy
  2.  Panel model not able to be selected on PV Modules tab (cut-off drop down form field) - therefore cannot progress designs
  3.  Inverter drop down in Configuration tab - form fields too tight horizontally so no spacing/tight
Does not look a great version upgrade currently.
Dear Stuart,
thank you for your feedback. We are having a lot of customer feedback about the GUI at the moment, and we are working on a solution. It seems that recent updates of Mircosoft Windows, as well as the .NET framework and additionally the handling of the dpi scaling changed.
So it would be very helpful if you could provide a screenshot of the pages with the issues you mentioned, and - if possible - some information about your display settings.
Thanks a lot in advance, kind regards,
