2020 R3 3d Modelling No icons i any menus
Hi
Strange things happening while I open 3D Modelling window - there is no icons in any section at all. In fact using 3d modelling is useless. Factory reset didn't solve the problem.
Any advice ?
Regards
Hello Martin
I've tried all the possible options You pointed to Ragy and additional options discovered by Ragy although nothing changed, still icons not shown in any menus .
So it seems that the problem is located in other area. I really don't know what to do.
Regards
Jacek
Hi Jacek,
another thing you could try then would be to manipulate you ini file. Close PV*SOL, and locate this file here:
C:\Users\USERNAME\Documents\Valentin EnergieSoftware\PVSOL premium 2020\PVSOL.ini
Open this file in a text editor (notepad++ is a good one ;) ) and locate the line (near the end of the file)
<MainPagerWider>0</MainPagerWider>
Replace it with
<MainPagerWider>-1</MainPagerWider>
save the file, and start PV*SOL again. For some customers, this works, so I hope this works for you as well..
Dear Martin
Good direction
I've done changes in the row You pointed , and now icons are visible in the menu sections and 3d modelling2020-02-17_17-09-21.thumb.png.537abf6767174d5dd45d9937dc08f24a.png2020-02-17_17-08-42.thumb.png.e7bcc14f22e30ac16f18127f599b13d8.png
is working although their shape is not optimal. Pls have a look at screenshot attached
Regards
Jacek
  • 1 year later...
