orientation
Hi,
I would expect the orientation to be "the same" on the south and the north side of a roof I am making calculations on.
Using a "east-west" system divided on south and north side of the same roof, in this example i get following orientation.
North Building:
  50% are 115° South-east + 50% at 307° North-west
South Building:
   50% are 127° South-east + 50% at 295° North-west
I would expect the orientation to be either 115°/295° or 127°/307° and not the mix of 115°/307° and 127°/295° that have been used in this simulation.
Why is this?
Best regards
Daniel
Hi,
yess ofcourse,
We have planned for panels on both sides of the ridge, expecting more consistent orientation.
On the south side of the ridge i get this,
And on the north side, this
Roof illustration
Best Regards
Daniel
Hi Daniel,
it looks like your roof has a ridge that is not exactly in North-South direction, is that correct? In that case, if you have a small inclination of the roof surface and you mount a PV system with its own orientation and tilt, the resulting orientation and tilt (or inclination) will be different. For that reason there is also a small dialog in the mounting system dialog that explains this a bit:
Click on Orientation -> Calculate
