July 9Jul 9 comment_21282 Been having an issue with the PVSOL export simulation results where the simulation results aren't showing the tab labelled "Current & Voltages". This hasn't been an issue previously, and even on more recent projects I've managed to get this info per inverter just fine. I've attempted clearing some of the error messages on the design (feed-in and grid tariff, dimensioning factors, etc.) to no avail neither. Now I'm thinking that maybe its a case of having too many inverters in the design itself? Not entirely sure. Any help with this would be greatly appreciated. Report
July 13Jul 13 comment_21287 Hi Cameron, could you send us a project file where this happens? Please send it to hotline@valentin-software.com, along with a link to this forum post. Thanks a lot, kind regards, Martin Report
August 5Aug 5 comment_21366 We would like to refer once again to your inquiry. Some simulation results are provided per module area. Unfortunately, this is only possible for up to 20 module areas. Projects with more than 20 module areas would need to be split into sub-projects in order to obtain the simulation results per module area. You're also welcome to send us your project file (to hotline@valentin-software.com) so we can take a closer look at it. Report
