Mark Posted June 1 Report Posted June 1 Good Day, I want to make sure if my calculations are correct. I added a Dyness PowerBlock Max 16kWh battery to the database. Please just check if my Discharge Cycles are correct below: Quote
hotline_oh Posted June 4 Report Posted June 4 Dear Mark, Thank you for your inquiry. Since you cannot enter 8,000 cycles at 70% EOL (DoD), enter 10,000 cycles at 60% EOL (DoD) (and have the remaining values calculated). Quote
Mark Posted June 11 Author Report Posted June 11 When I try to change the value at 60% DOD to 10000 and do the Calculate cycles then that value just returns back to the values that it was. Nothing changes. Also please give me the formula to determine a batteries DOD at 60% from the datasheet. Quote
hotline_oh Posted June 17 Report Posted June 17 Dear Mark, We apologise: for lithium iron phosphate batteries, the reference value used to calculate discharge cycles is not a DoD of 60% (as with lead-acid batteries), but a DoD of 40%. You can simply enter these four values manually: We are still awaiting feedback from our development department regarding the formula. Quote
Mark Posted June 20 Author Report Posted June 20 Thanks, please share with me as soon as you get that formula. Quote
hotline_oh Posted June 23 Report Posted June 23 Dear Mark, Thank you for your message. For lithium iron phosphate batteries, the reference value used to calculate discharge cycles is based on a DoD of 40%. This results in the following factors for the discharge cycles: DoD Value 0.2 2.206563 0.4 1 0.6 0.598166 0.8 0.397315 Quote
Mark Posted June 23 Author Report Posted June 23 Good Day, my question was actually, what the formula is to calculate the battery DOD at 40%. As per below, it does not reflect what you are getting. Â Quote
Mark Posted Thursday at 01:39 PM Author Report Posted Thursday at 01:39 PM Any feedback yet on my question above? Quote
hotline_oh Posted Monday at 11:24 AM Report Posted Monday at 11:24 AM Dear Mark, Thank you for your message. The formula is correct, but the exponent (0.55) is not a standard constant; it varies depending on the battery type and even within a single battery type. PV*SOL Premium uses a value of 1.3278; this value models lithium iron phosphate batteries with sufficient accuracy. Unfortunately, we are unable to model higher accuracy (using variable exponents). Quote
Mark Posted Monday at 03:42 PM Author Report Posted Monday at 03:42 PM Thanks, so in place of the 0.55 constant I must use the 1.3278 constant. Correct? Quote
hotline_oh Posted 19 hours ago Report Posted 19 hours ago Dear Mark, Thank you for your message. Yes, we confirm that you must use the exponent 1.3278 instead of 0.55. Quote
