Hey dev Team,
I have a couple of cases where I am supposed to use a Tesvolt battery with emergency power and other case without emergency power
TS40 Speicher mit 28,8 kWh und 18 kW Leistung ohne Notstrom
TS40 Speicher mit 28,8 kWh und 18 kW Leistung mit Notstrom
However, i haven't found these options (with and without emergency power) with the Tesvolt battery in PV Sol
My question is what difference the emergency power would make in the end simulation result ?
Should i expect more standby consumption in the latter case?
Thank you
Hello Vishnu,
You might be right that the standby consumption of the system with emergency power is higher, but one way or another, I don't think you would see a big difference between these systems.
To be on the safe side, you can ask the manufacturer if the standby consumption is different between these options.
Marcel
