Brano Lalic Posted November 21, 2025 Report Posted November 21, 2025 By choosing panels from the base, Trina Solar TSM-705NEG21C.20 Vertex N Bifacial 705 W, or Trina Solar TSM-705-NEG21C.20 VERTEX N 2024 705 W, which have identical characteristics, in an outdoor setting, I get large differences in production estimates. Why? Quote
developer_mh Posted November 27, 2025 Report Posted November 27, 2025 Hi Bruno Lalic, the difference comes from the low light parameters: left: "TSM-705NEG21C.20 Vertex N Bifacial 705 W" right: "TSM-705-NEG21C.20 VERTEX N 2024 705 W" In one case, the manufacturer has chosen the "standard low-light performance", which defaults to the two-diode-model for this module. In the other case, the manufacturer entered low light values himself, that is, defined values for voltage and current at 200 W/m². Hope that helps, kind regards, Martin Quote
hotline_oh Posted December 2, 2025 Report Posted December 2, 2025 Dear Brano Lalic, We refer once again to your inquiry. We created the data set for the TSM-705NEG21C.20 Vertex N Bifacial module ourselves at a customer's request. Later, the manufacturer created the data set for the TSM-705-NEG21C.20 VERTEX N 2024 module. One difference between the data sets was the low-light performance. We had used the standard low-light performance, but have now adopted the low-light performance entered by the manufacturer. Another difference was the incident angle modifier (IAM). We had assumed 95%, resulting in -4.19% losses due to reflection at the module surface. The manufacturer entered 100%, which we consider unrealistic. We have now adopted 99.9% in our data set. Quote
Brano Lalic Posted December 2, 2025 Author Report Posted December 2, 2025 Veliko hvala. 46 minutes ago, hotline_oh said: Poštovani Brano Lalić, Još jednom se osvrćemo na Vaš upit. Skup podataka za TSM-705NEG21C.20 Vertex N Bifacijalni modul smo sami kreirali na zahtjev kupca. Kasnije je proizvođač kreirao skup podataka za TSM-705-NEG21C.20 VERTEX N 2024 modul. Jedna razlika između skupova podataka su performanse u uslovima slabog osvjetljenja. Koristili smo standardne performanse u uslovima slabog osvjetljenja, ali sada smo usvojili performanse u uslovima slabog osvjetljenja koje je unio proizvođač. Druga razlika je bio modifikator ugla upada (IAM). Pretpostavili smo 95%, što je rezultiralo gubicima od -4,19% zbog refleksije na površini modula. Proizvođač je unio 100%, što smatramo nerealnim. Sada smo u našem skupu podataka usvojili 99,9%. Quote
