Renan Posted May 18, 2019 Report Posted May 18, 2019 I made a simulation of the same building with exactly the same PV-system but for different locations. But in the one case the standby consumption of th einverter is 24 kWh/a and in the second case 26 kWh/a. What could be the reason for this difference? I checked all the input data douple and they are similar in both cases. Quote
developer_mm Posted May 20, 2019 Report Posted May 20, 2019 Hello Renan, the total stand-by consumption also depends on the irradiation/ climate data of the selected location. This means that a site has reached more phases in which the inverter has not reached its minimum feed-in energy from the pV system, so the inverter switches to stand-by mode. (https://help.valentin-software.com/pvsol/2019/databases/components/inverter/#electrical-data Kind regards, Marcel Quote
Felix Galan Posted August 11, 2025 Report Posted August 11, 2025 Hi, I have a question regarding how module degradation might affect standby consumption. I've noticed a discrepancy in the first-year generation figures: the simulation results show 792,161.3 kWh, while the report states 792,333 kWh. Please see attached screenshots. Could this difference be attributed to standby consumption being 72 kWh instead of the 86 kWh mentioned in the report? Thank you. Kind regards, Felix Galan Quote
developer_mh Posted August 13, 2025 Report Posted August 13, 2025 Hi Felix, could you send me the project file, please? You can send it here in the forum as private message to me, so I can have a look, thank you. Kind regards, Martin Quote
Felix Galan Posted August 19, 2025 Report Posted August 19, 2025 I replied via DM, attaching a similar model that has the same issue. Thanks. Quote
developer_mh Posted August 20, 2025 Report Posted August 20, 2025 where did you send it? I did not receive a message from you. Kind regards, Martin Quote
Felix Galan Posted August 22, 2025 Report Posted August 22, 2025 Hi Martin, Below the link to the message https://forum.valentin-software.com/messenger/454/ Kind regards, Felix Quote
hotline_oh Posted August 27, 2025 Report Posted August 27, 2025 Hi Felix, unfortunately, we did not receive your message. Please send us your project file (*.pvprj) by e-mail to hotline@valentin-software.com so that we can take a closer look at it. Quote
