CarlSEL Posted June 3, 2025 Report Posted June 3, 2025 Hi, I have noticed that when a certain amount of inverters are used the Performance ratio per inverter graph only gives one value. Is there a way of getting each individual PR ration per inverter for a site using 12no 40kW inverters? Thanks Carl Quote
hotline_oh Posted June 17, 2025 Report Posted June 17, 2025 Dear CarlSEL, Thank you for your inquiry. The limiting factor is the number of module areas. For systems with fewer than 20 module areas, separate values for irradiation and performance ratio are output. For systems with 20 or more module areas, only one value can be output due to the complexity. Quote
