Alexclavijon Posted May 15, 2019 Report Share Posted May 15, 2019 I want to create an offgrid photovoltaic plant but i have 2 main errors: - My load is constant every day and every hour, when i import a load profile as a constant load it will shape the profile and my load won't be constant anymore, it will vary every month. How can i create a constant load profile so i have the same energy conpsumed every month? - The second problem is that i have my own battery inverter for my project, but when i want to select it will only show me Sunny Island inverters, how can i see every inverter in the database? create the inverter in the program is not a solution because i don't know all the detailed data that PVSOL ask to create a new entry. Thanks for answer. Quote Link to comment Share on other sites More sharing options...
developer_mm Posted May 16, 2019 Report Share Posted May 16, 2019 Hello Alexclavijon, Regarding your first question, you have to decide which scenario you want. Because a constant load profile and the same energy consumption per month are two different things. For example, if you have a constant daily consumption of 10 kWh, the total consumption for January is 310 kWh (10 kWh * 31 days) and the total consumption for February is 280 kWh (10 kWh * 28 days). To get a monthly constant load profile of e.g. 310 kWh, you would need a daily consumption of 10 kWh for months with 31 Days, and 10.3 kWh for months with 30 days. Regarding your second question: For off-grid systems, only battery inverters from SMA are currently available. If you want a different battery inverter, you must create it yourself. You should find all the necessary information in the data sheet. Kind regards, Marcel Quote Link to comment Share on other sites More sharing options...
