Rok G Posted November 13, 2024 Report Posted November 13, 2024 Hi, I am trying to finish one of my projects and cabling was mostly done automatically. However, for some reason one roof (flat) did not cable (even though string is as it should be). When I try to cable manually, there is no option to put cable on grommel anywhere - in fact, I cannot make any cabling manually for any roof type. Please see attached photo of a Cable Plan menu where there are no visible options that usually are, such as Cable, Cable Nodes etc. Why is that? How I can finish the project? Thank you. Best regards, Rok Quote
hotline_oh Posted November 13, 2024 Report Posted November 13, 2024 Dear Rok, Thank you for your inquiry. Unfortunately, the cable plan is not available for elevated systems or for polystring configurations. There is only the automatically created string plan, which is based on the configuration. Quote
Rok G Posted November 13, 2024 Author Report Posted November 13, 2024 11 minutes ago, hotline_oh said: Dear Rok, Thank you for your inquiry. Unfortunately, the cable plan is not available for elevated systems or for polystring configurations. There is only the automatically created string plan, which is based on the configuration. Hi, thank you for your answer. For this particular roof there is no cable on the string plan. So I get every time notification that "at least one cable is incomplete". What can I do to overcome this? Thank you. Quote
hotline_oh Posted November 14, 2024 Report Posted November 14, 2024 Dear Rok, Thank you for your message. This notification has no influence on the correct simulation and can be ignored. 1 Quote
