April 8, 20197 yr comment_2395 Good afternoon,Today has been a great day with situations in PVSol !!!!!I'm trying to import 1 SketchUp 3D model and PVSol always gives me the same information. I have already recorded the Sketchup project several times and imported it into PVSol, as well as restarted the PVSol a number of times, but always without success. Report
April 9, 20197 yr comment_2397 Hallo Marta Gonçalves, could you provide us the sketchup file? Kind regards, Marcel Report
April 9, 20197 yr Author comment_2398 HiThank you for your help. Can you give me an email address to send the project? Through this forum the attachments can have a maximum of 163 kb. Best regards, Marta Gonçalves Report
April 9, 20197 yr Author comment_2402 Hi 32 minutes ago, developer_mm said: You can send me the data via private message. HiI can send the project with no problem. The point is that by here the limit is 160 kb.Can you send me an email to which I can resend sketchup? Best regards, Marta Gonçalves Report
April 9, 20197 yr Author comment_2403 if you do not want to send the email here, send me a message to: marta.goncalves@sotecnisol.pt Report
April 24, 20197 yr comment_2458 hi .. please could you tell me what is the best range of performance ratio and yearly shading losses in a 3D design for a mounting roof project .. thanks Report
April 25, 20197 yr comment_2461 Hello Mohamed Khaled, it's pretty hard to say because it depends a lot on your project and your design decisions. The best is of course a PR of 100% and losses of 0%, the negative impact depends on the project. Kind regards, Marcel Report
April 30, 20197 yr comment_2486 the error that appears to you is because you have the Sketchup file opened with another process. You have to have it closed to open with PVSol Report
