Omer Posted September 9, 2024 Report Posted September 9, 2024 Hi guys, So I've made the update for PV Sol from R6 to R7 and unfortunately I have a big failure.Creating the string plan through PV*SOL is very good in saving time for me. Unfortunately I have the following failure where the modules show the correct rows that the string should follow but when it generates it , it generates it totally wrong. Normal Path would be like shown above ... but please see below what it's generating me: Thank you in advance! Quote
hotline_oh Posted September 11, 2024 Report Posted September 11, 2024 Dear Omer, Please send the corresponding project file (*.pvprj) to hotline@valentin-software.com so that we can take a closer look at it. Quote
hotline_oh Posted October 1, 2024 Report Posted October 1, 2024 Dear Omer, Thank you for your inquiry. The course of the strand depends on the configuration. If you have already created a cable plan and subsequently make changes to the wiring, the cable/string diagram is not always updated. You must then delete the cable plan, switch back to the Module wiring page and then back to the Cable plan page. Everything is then updated and the cables run in a meandering pattern. You can find an example here: Quote
