RobS Posted March 22, 2019 Report Posted March 22, 2019 Hi I have a new laptop and the usual icons do not show in 3D design view. I notice this bug has been raised before.  I have attached the ini file could it be that? PVSOL.ini Quote
RobS Posted March 22, 2019 Author Report Posted March 22, 2019 Hello I tried this which you recommended to another user 2019\PVSOL.ini Open it in a text editor and search for the element <MainPagerWider>0</MainPagerWider> Change it to <MainPagerWider>-1</MainPagerWider> and save the file Start PV*SOL premium It had this effect; Is that how the icons are supposed to look?  do you know what is causing the issue? Thanks Quote
developer_mm Posted March 22, 2019 Report Posted March 22, 2019 Hello RobS, no, the icons should not look like this It should look like this: Â As far as we know, the problem occurs with newer monitors, for which we have not yet found a satisfying solution. Kind regards, Marcel Quote
RobS Posted March 22, 2019 Author Report Posted March 22, 2019 ok thanks at least I can use the software now Quote
RobS Posted March 22, 2019 Author Report Posted March 22, 2019 Hello Marcel. FYI the latest windows update fixed the issue.   Quote
developer_mm Posted March 22, 2019 Report Posted March 22, 2019 Wow, that would be amazing. Thank you for sharing this information. Quote
