Mircea Balatescu Posted June 21 Report Posted June 21 Hi when designing east-west arrays, the default numbering of panels is like in below figure: this type of nuberig results in a string diagram like below figure, which is not correct the correct numbering of panels should be like this: resulting in a string diagram like this, which is correct Can i achieve this configuration without moving panels manually? Quote
Sam Posted June 28 Report Posted June 28 Hi there, you can change the sequence of modules or strings in Menu : Options - Module Configuration - Sorting - Sequence of modules - Course : meander (instead of simpel) I hope that would be helpful.  Best Regard Sam Quote
developer_fw Posted July 2 Report Posted July 2 Hello Mircea Balatescu Thank you for your request and thank you for your response, @Sam. For being able to number your configuration like you did show in this screenshot: you should know about the selection of modules in the 3D environment first. Instead of configuring all modules at once you could pre-select the rows you wish to configure separately by drawing selection, holding CTRL for adding to the selection and adding them to the configure dialogue via the context-menu: (1) Right-click (2) Configure the selected modules By doing this preparation your automatic numbering should be more easy. Kind regards Frederik Quote
