CDB Posted May 10, 2024 Report Posted May 10, 2024 Hello, is anyone else having issues with PVSol 2024 (R6) constantly crashing and showing this error message? Error message = "Fehler beim Mesh generieren" Quote
developer_fw Posted May 13, 2024 Report Posted May 13, 2024 Hello CDB This error message could appear if you do want to import a 3D object that is too big or broken and cannot be handled by PV*SOL. Is it possible to simplify your model before importing it? Did you get into contact with our technical support? You could send the object which you are trying to import into PV*SOL so I could have a look into it. Thank you in advance and kind regards Frederik Quote
Cornelia KS Posted May 16, 2024 Report Posted May 16, 2024 I am also having this issue but I get either "Fehler beim Mesh generieren" or "Fehler beim Locken eines Vertexpuffers" as the error message. I never use the import 3D object because I build everything from scratch, so that isn't the reason for my crashes. Quote
developer_mo Posted May 16, 2024 Report Posted May 16, 2024 Hello Cornelia KS, thank you for your Report. 1 hour ago, Cornelia KS said: or "Fehler beim Locken eines Vertexpuffers" as the error message. Are you using a RDP connection to the computer that runs PV*SOL? When and how often does this error occur? 1 hour ago, Cornelia KS said: I do not import 3D objects. This ("Fehler beim Mesh generieren" without utilizing the 3D Import) is a strange behavior that I'm not yet familiar with. Could you share your project here or send it to me via private message in this forum, so that I could have a look at it? Kind regards Mikio Quote
jon henderson Posted July 24, 2024 Report Posted July 24, 2024 Hi, I have just has 4 system crashes half way through detailed design. sent bug report. This happens several times a week and wasting a lot of time. Can you PVsol) contact me to discuss Quote
developer_fw Posted July 25, 2024 Report Posted July 25, 2024 Hello jon henderson 20 hours ago, jon henderson said: I have just has 4 system crashes half way through detailed design. sent bug report. This happens several times a week and wasting a lot of time. Can you PVsol) contact me to discuss Sorry for the inconvenience. Could you send me your ticket numbers via private message here in the forum so I can have a look into them? Kind regards Frederik Quote
danny_lang81 Posted August 2, 2024 Report Posted August 2, 2024 I am also having issues with it crashing. The few days it has constantly crashed and froze. Nothing seems to have saved. It is stating 3D visualization has crashed when i try to force to end the programme in task manager. The computer is the same i have always used for PVSol. any assistance would be greatly appreciated kind regards Danny Quote
developer_fw Posted August 15, 2024 Report Posted August 15, 2024 Hello danny_lang81 Sorry for the inconvenience and for getting back late. Did you contact our hotline support for help? https://valentin-software.com/en/support/technical-support/ They will be happy to help you out. Kind regards Frederik Quote
