timgreen13 Posted February 22, 2019 Report Posted February 22, 2019 Dear Support, As you can see from the picture attached i got high loss in the  MPPT voltage range(13%) when i looked closer on every inverter separately i see the DC/AC conversion loss is high why is that ?   losses per inverter total loss Quote
developer_mm Posted February 25, 2019 Report Posted February 25, 2019 Hi Tim, just with this table it's hard to say, but I guess since you're using a Solar Edge inverter, this might be due to your inverter configuration and how you using the Power Optimizer. Kind regrads, Marcel Quote
