Ryan PSE Posted April 8, 2024 Report Posted April 8, 2024 Hello, I know the PVSOL system defaults to 470 g/kWh for the CO2 saving, I have updated this to 193 to reflect the government figures but even though I click Save as Default, it keeps defaulting back to 470. Any advice? Many Thanks Ryan Quote
developer_fw Posted April 9, 2024 Report Posted April 9, 2024 Hello Ryan PSE On 4/8/2024 at 11:09 AM, Ryan PSE said: Any advice? Please check if the file "C:\Users\<YOURUSERNAME>\Documents\Valentin EnergieSoftware\PVSOL premium 2024\PVSOL.ini" contains the following line (similar): Try to close all instances of PV*SOL and check if the default value is displayed correctly. Does this help? Kind regards Frederik Quote
Ryan PSE Posted April 11, 2024 Author Report Posted April 11, 2024 Hi Frederik, I do have that and it is set to 193.  Quote
developer_fw Posted April 11, 2024 Report Posted April 11, 2024 Hm, I cannot reproduce your issue. Which version of PV*SOL are you using? Kind regards Frederik Quote
developer_fw Posted April 15, 2024 Report Posted April 15, 2024 Hello Ryan PSE On 4/8/2024 at 11:09 AM, Ryan PSE said: but even though I click Save as Default, it keeps defaulting back to 470. Any advice? I thought about your issue again: This does not (and should not) work for existing projects, but your issue seems to be existent for any new project? Kind regards Frederik Quote
