developer_fw Posted March 14, 2024 Report Posted March 14, 2024 Hello Connar Bentley, yes, you do need to define mounting surfaces. You could continue with the following: 1. Let PV*SOL determine the mounting surfaces for you Open the Edit dialogue of one building via the context menu (right mouse click): Let PV*SOL try to determine mounting surfaces. I recommend to also use the imported object as terrain model in order to avoid transparency and flickering while working with it: After closing the dialogue you could activate a mounting surface and continue with placing modules 2. Paint the mounting surfaces onto your models yourself Kind regards Frederik 1 Quote
Connar Bentley Posted March 14, 2024 Author Report Posted March 14, 2024 That's brilliant, thanks for your reply Frederik! Quote
