Hi Tim,
we just discussed it here. We think you should go and try modelling the house in sketchup and then import it in PV*SOL. Even if you have to learn to use sketchup first, you will be faster in the long run. Modelling these types of buildings in PV*SOL with polygons will be very tricky.
One of our 3D team members modelled this house in 20min. He used sketchup a lot, so perhaps you will need more time for your first models, but in the end you can really save a lot of time when you have a lot of those complex buildings.
Hi Martin,
Thank you for the answer !
is it possible to show the result of your team member?
so after i do in in sketchup -i need to import it? with the 3D model import function ?
Thanks
