Akvi_2 Posted February 5, 2024 Report Posted February 5, 2024 Hello, I haven't found any clear information or straightforward suggestions for how to do curved roofs on PVSol. I saw one suggestion to make 2m wide single pitched roofs and join them together, but if the building is large or complicated, this option will take too long. Another suggestion I received was to add attic layers to the pitch roof, but this doesn't work for me. Could someone please show me a step-by-step solution? Screenshot attached - this is what happens when I add attic layers (it does not work for me!) Thank you in advance. Quote
developer_fw Posted February 6, 2024 Report Posted February 6, 2024 Hi Monika For such a task I would not recommend PV*SOL, but a real CAD software. After creating such a model you could automatically create module areas onto the object. They have to be flat: After the automatic determination -- it works for simple surfaces like this -- you could start placing modules. Does this help? Kind regards Frederik Quote
Akvi_2 Posted March 1, 2024 Author Report Posted March 1, 2024 Hello Frederik, I don't have access to other software for making models. I had access to one of the PVsol files where curved roof was created using PVsol only. I would like to find out easier solution rather than jumping from one software to another. Many thanks. Quote
developer_mo Posted March 12, 2024 Report Posted March 12, 2024 Hi Akvi_2, thanks for your question. I understand, that it would be easier to create the building and the pv system in the same software. Fortunately, this is possible in PV*SOL for many building types. However for creating complex curved roofs PV*SOL is currently not very suitable, as Frederik pointed out before. One possibility would be to use a free CAD program such as FreeCAD to create the building there and then import it into PV*SOL. On 3/1/2024 at 4:30 PM, Akvi_2 said: I had access to one of the PVsol files where curved roof was created using PVsol only. May I ask which PV*SOL project you mean? If you mean our example project '3D Barrel Roof', you can find it on the PV*SOL start page on the right under 'Example Projects'. Perhaps you can also use this project as a template for your building. Kind regards Mikio Quote
