January 15, 20242 yr comment_14970 Is there a way to change a manufacturer's information, if it is confimed by manufacturer that it is wrong. Report
January 15, 20242 yr comment_14971 Hello Anson Thank you for reporting this error. I just updated the record which will be shown correctly with the upcoming DB update. 5 hours ago, Anson said: Is there a way to change a manufacturer's information System data records are immutable by design. You could copy system data records as your own to make changes. Kind regards Frederik Report
January 16, 20242 yr Author comment_14986 Thank you for prompt reply. I saw the website showing in the data is not correct. It is now https://www.dlg-battery.com and the correct one should be https://www.pytesess.com/ Would you mind correcting it? Report
January 16, 20242 yr comment_14988 Hello Anson 7 hours ago, Anson said: Would you mind correcting it? I did. Thank you for reporting! Kind regards Frederik Report
January 16, 20242 yr Author comment_14992 Sorry but it's still showing https://www.dlg-battery.com there. Report
January 16, 20242 yr comment_14995 Hello Anson This is correct. Changes within the manufacturer database are not immediate but have to be published into another database which is accessible from PV*SOL. This release cycle takes place every now and then at non-specified intervals; please be patient. You could check historic changelogs from PV*SOL: https://help.valentin-software.com/pvsol/2024/en/databases/#changelog Kind regards Frederik Report
