Emile Posted November 22, 2023 Report Posted November 22, 2023 Hey Team Valentine,  I created a new Bifacial module for my simulation with 70% Bifacial Factor. However, when I run the simulation, I get absolutely no gains or losses in the PV System Energy Balance. What could be the cause of this?  Your help would be much appreciated.  Sincerely, Emile Quote
developer_fw Posted November 22, 2023 Report Posted November 22, 2023 Hi Emile 13 minutes ago, Emile said: What could be the cause of this? Hard to tell. Might you be so kind and send your .pvprj project file via private message here in the forum so I can have a look into it? Thank you in advance and kind regards Frederik Quote
Emile Posted April 18, 2024 Author Report Posted April 18, 2024 Hi Frederik,  My apologies for the late response. Hereby the files. Would appreciate it if you would have a look at them.  Thanks in advance.  Kind regards, Emile Bol.com Waalwijk Links -addition.pvprj Bol.com Waalwijk Links.pvprj Quote
developer_mo Posted May 17, 2024 Report Posted May 17, 2024 Hi Emile, thanks for sharing the projects. I also apologize for the late reply. My assumption is that bifacial modules are not very suitable for an east-west system, as very little irradiation reaches the back of the module. On 11/22/2023 at 11:00 AM, Emile said: I created a new Bifacial module for my simulation with 70% Bifacial Factor. Furthermore, I noticed that in the project that you posted, the bifaciality factor for the module is only 20% and not 70% as you wrote. Was that your intention? I'm sorry if I misunderstood something. Please contact me again if this doesn't answer your question. Kind regards Mikio Quote
