Hello,
For a PV System with capacity 200 kwp  i am using two inverters: Tauro eco 100-3-d
From softuer i have configuration :
Inverter 1: Tauro eco 100-3-d loaded with 112 kwp and
Inverter 2: Tauro eco 100-3-d loaded with 88 kwp.
What can i do in this situation to unload Inverter 1
Regards,
Graniti
Hi Graniti,
do you want to configure the modules manually? Or do you want to get automatic configurations with only one inverter? In your example, the inverter is too small to take all the modules, so you will have to use two. Could you explain what you want to achieve exactly?
Thanks and kind regards,
Hello Martin,
I selected to use inverter Tauro Eco 100-3-D and then from automatic configuration a have thate result.
From automatic configuration i have 2 inveters but inverter 1 is loaded with 112kW and the other one only with 88kW.
In this way MPPT of inveter 1 is overloaded.
