jamesbm Posted May 9, 2023 Report Posted May 9, 2023 Hi PVSOL team. I find integrating modules annoyingly hard (it worked in the past). Very often it fails (see attached image). The error says there is a collision even when there is plenty of room around both arrays. Is this something you could fix or can you suggest a workaround? Thanks James Quote
developer_fw Posted May 9, 2023 Report Posted May 9, 2023 Hello jamesbm thank you for reporting! 2 hours ago, jamesbm said: Is this something you could fix or can you suggest a workaround? This definitely should not happen in the case you have shown. Could you send me your project file so I could try reproducing the error and delegate it with your report? Thank you in advance and kind regards Frederik Quote
