Daniel93 Posted May 3, 2023 Report Posted May 3, 2023 Hello, I have downloaded PV*SOL for a university project, then put a document in the path (given by the professor for unlimited use). The Test version is running, but for the wanted use over the VPN, there is an error: The connection with the remote server could not be done. The application will be closed. could you please help me there? Thanks in advance Quote
developer_fw Posted May 4, 2023 Report Posted May 4, 2023 Hello Daniel93 thank you for your request. You might open a PowerShell and check the connection to our license server. Press Win, type powershell, press Enter Execute the command: Invoke-WebRequest -Uri "https://license.valentin.de/" -Method Head -Verbose StatusCode must be 200 You could also post the output here. There is a list of URLs that are mandatory for using PV*SOL in our online help: https://help.valentin-software.com/pvsol/2023/en/start/system-requirements/#internet-connection Kind regards Frederik  Quote
