Prosolar Posted April 25, 2023 Report Posted April 25, 2023 Hello dear users I have a very annoying problem loading "load profiles" into PVsol. I usually get my information from the customers with meterdata on an hourly basis. Even though it's meterdata giving me a excel sheet with 8760 lines there is rarely strait numbers like 1, 5 or 12. The numbers are usually 10,2312, 43,411 etc. Now if it happens a file contains 1 or 2 strait number, normally I would manually find them in the sheet and change them from 2 to 2,0001 for an example. Once I have change all the strait numbers to numbers with decimals the profile can be loaded into PVsol. Unfortunally now I got a customer with 2 different "load profiles" with all strait numbers, which leaves me with a big problem. It will take me FOREVER to manually change all the numbers to numbers with decimals. Do any of you know a way to work around this or make PVsol accept "load profiles" without decimal numbers? Thanks in advance for your help Quote
developer_fw Posted April 25, 2023 Report Posted April 25, 2023 Hi Prosolar 17 minutes ago, Prosolar said: Do any of you know a way to work around this or make PVsol accept "load profiles" without decimal numbers? Of course! Here you go: Mark the column Right click to open the context menu Choose "Format cells..." Select Number Set decimal places to greater than 1 Confirm by clicking OK Be happy about Excels functionality and the free time you do never have to use for spotting unformatted numbers manually! Kind regards Frederik 1 Quote
Prosolar Posted April 25, 2023 Author Report Posted April 25, 2023 Thanks friend, that is going to save me a shit ton of time  Quote
